Do you mean
Reply
How to calculate the Centre of Gravity for an assembly in NX9?
Hello All,
I want to calculate the Centre of Gravity of an assembly. Please tell me how to calculate COG for a large assembly.
Rahul
Re: How to calculate the Centre of Gravity for an assembly in NX9?
Analysis, Measure Bodies
This should create a point, at the Cg location.  This assuming you have the proper densities assigned to the components.
-Dave
NX 9 | Teamcenter 10.1 | Windows 8.1
Hello Dave,
Thanks for reply.
As per your above reply we will check only COG for single component. I have tried it already. If you know the procedure to check COG for a big assembly then please tell me thoroughly.
Rahul
If you select all of the Components in the Assembly you'll get the COG of the entire Assembly.
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Thanks Dave.
