Do you mean
Reply
Solved! Go to solution
Importing a Title Block template
Is there a way to import the sample title block that comes with NX? I would like it modify it and not start from scratch. The "Define Title Block" on the Drafting Tools tab seems to work only after creating a "Tabular note" which is on the "Home" tab. Im new to the drafting module, but the placement/flow of the commands seems unintuitive. The Define Title Block command seems too look for existing data and not actually "create" a title block.
Solution
Solution
Accepted by topic author TechniCsNC
‎11-08-2016 02:11 PM
Re: Importing a Title Block template
Have a look at https://vimeo.com/album/3065578 there's a video there I created which explains the title block functionality.
Anthony Galante - Senior Support Engineer - PhoenxPLM (Australia & New Zealand Siemens Solutions Partner)
http://www.phoenxplm.com.au/email/2014_signature/signature_videoCenter.jpg
