Do you mean
Reply
Kinematic motion simulation in NX 10
how to make same mechanism in NX???
https://youtu.be/eAbcixj7Occ
Re: Kinematic motion simulation in NX 10
You will probably need MCD (mechatronics concept designer) for it. I will suggest that you post this query on NX Simulation forum also.
Best Regards
Kapil
As the mechanism is very simple (and you won't be able to simulate body deformations in MCD), you can alternately use the expression-based animation.
see this thread: Click
However, MCD would allow you to connect the NX model with a controller via OPC.
Johannes
Sir can u suggest any tutorial links??
There are some available on youtube for MCD
https://www.youtube.com/watch?v=-dvaZ7WHoNA&list=PLGbHjPQfC-EiisdOW3530-e5r8dM21XHq
Best Regards
Kapil
