Do you mean
Reply
Solved! Go to solution
back to absolute origin
Dear Community
is there a way to place constrained or moved components back to their absolute origin position, once their constraints are inactivated or deleted of course.
I am looking for some functionality that is very similar to the "unexplode" function.
Thanks in advance
Marco
Re: back to absolute origin
I am not sure of any short cut way of doing the same but there is a workaround.
The main CSYS of the main assembly is the absolute csys so you can
use move component (CSYS to CSYS) to regain back your absolute position (by selecting the csys of the component and the absolute CSYS of the main assembly)
Kapil
thanks, this would always work for one component alone.
What I am looking for is a method to apply to lets say 100 pieces where the move option is not viable anymore.
Thanks for your suggestion
Solution
Solution
Accepted by topic author mascaritas
‎12-02-2016 04:40 AM
Some journal code to do this can be found here:
http://nxjournaling.com/content/reset-component-position
I would suggest removing all constraints from the component in question before running the journal on it; I'm not sure how a partially constrained component would react.
That Program that Cowski1 has works great.
Great thank you.
I will try to add a multiple selection and a loop into that journal and it will be exactly what I was looking for .
Best Greetings
Marco
