Do you mean
Reply
Solved! Go to solution
hd3d tools issue managment
I created one issue in my issue managment (nx hd3d tools)......
if i want to send the issue to other department it is asking for the login details for issue data server ..........
So how can i get those details ...is it possible ?  and what are the requirements for that....
Thanks in advance......
Re: hd3d tools issue managment
There are 2 approaches to doing this.
It does depend if you are in managed environment or not.
From what you describe you are trying to share issues via the Teamcenter Issues management capabilities, so in that case you need your Teamcenter login and the issue management tools in Teamcenter.  This is the best way because it gives you a tracking mechanism and is all managed.
BUT, If you don't have this you can save the issue into an Issue Briefcase.  This creates an .ibp file which is a container for your data, you could then share that data, but of course if you aren't in a managed environment you are going to be sending copies of data around which you will have to resolve.
Paul
Solution
Solution
Accepted by topic author GOLI
‎12-15-2016 11:50 PM
Thank you for your kind information......
I got exactly what i expected....
