Do you mean
Reply
nx10 fastest constraining ( macro )
Hello ,
I would like to know easiest & fastest way to constrain two bodies in NX10...
Its consuming too much time while constraining hardwares,washers or any other part body...
Does you have any micro regarding to this for NX10
Akash119
Re: nx10 fastest constraining ( macro )
Note for "standard" parts (e.g. nuts/bolts/washers) you can "pre-define" assembly constraints in the component part. (if part families, this can be done in the part family master)
Then you only have to choose geometry on part it is being constrained TO.
For nuts/bolts/washers, a "concentric" constraint seems to be the least picks, but you may prefer something else.
I'd rather be steemed than diseaseled
