Do you mean
Reply
Solved! Go to solution
work part display behaviour NX10
hi Experts,
a costumer ask me about how to change display behaviour of work part in assembly.
They want rest of components in assembly do not change display when a component
is  selected as  work part.
As a default ,when a component is selected as a work part ,the rest of components do not display
as the work part (they want change this behaviour).
I try to find any customer default to change this but at the moment no one seems to works.
Any idea about it ?
Solution
Solution
Accepted by topic author FidelM
4 weeks ago
Re: work part display behaviour NX10
Hi @FidelM,
I'm not 100% sure what you're asking for, but you could try this:
Menu > Preferences > Visualization > Emphasis (tab)
Under Session Settings - Emphasis Precendence, uncheck "Work Part".
This prevents the non-work part components from dimming, and hence the work part being emphasised.
Regards, Ben
Thanks a lot Ben.
That is OK .....I changed Customers Default -->Gateway-->Visualization-->Work Part (uncheck) in order the change is persistant in following sessions.
Best Regards and Happy Christmas!
