Do you mean
Layer in NX 9 or NX 10
by Creator on ‎05-24-2016 03:19 PM - edited (1,524 Views)
This tutorial will help you understand usage of Layer & other related commands to Layer.
Question: How important is Layer command in NX?
  • Layer is most important when you are working in Part Modeling.  Assume you are creating a geometry of any part needs updating more than one time, but a backup is a must. That's where you should use Layer.
  • When you have one main Assembly Constraints with a large number of smaller assemblies, you should separate it by Layer, so it is easy to hide, unhide, lock, etc.
One of my viewers suggested  I record this tutorial of Layer,
So, here I explain how to use Layer & other related commands as follows:
- Layer
- Move to Layer
- Layer Settings
- Layer Category
- Copy to Layer
Have any questions? Comment below.
Contributors
