Do you mean
NX Quick Tips - NX 9 Fit Curves
by Community Manager Community Manager ‎02-04-2015 04:37 PM - edited ‎02-06-2015 02:14 PM (868 Views)
You can use the Fit Curves command in NX to create a quadric curve or a spline by fitting it to Scanned Data.
You can fit splines, lines, circles, and ellipses.  The splines, circles and ellipses, can be open or closed.
The key benefit is that this is all feature-based geometry, and it is fully integrated into the NX ecosystem.
In this NX Quick Tips video, Tod Parrella shows us how to use the Fit Curves command in NX 9.
This post originated in the NX Design Blog. You can view original comments on this post here.
Contributors
