Do you mean
Reply
Automating Line Item Copy
I have a situation where I need to copy the line item I currently have open to a new line item with some modifications. I'm pretty confident that I can do this by exporting the model XML (or some portion, most likely), and then using Unattended Engineer to create a new line item from the exported XML.
My question is this: Is there a way to automate this import into a new line item WITHOUT Unattended Engineer? I cannot think of a way to create a new line item while I have one open.
Re: Automating Line Item Copy
[ Edited ]
I think, in theory you can do it programmatically from the UI modifying the Project databases.
1. We need to create a copy of row with your line item in dbo.LineItem and dbo.Model changing the LineItem_ID to the unique value.
This will create a line item with fully reverted model.
2. We need to modify dbo.Model_Part, dbo.Model_Property and dbo.Model_SubPart tables. We need to create the copies of the rows with the LineItem_ID of your current project changing this ID to the new LineItem_ID.
I did it using the Management Studio and it works (at least I was able to create a new line item and get the values of properties copied)
Probably we'd like to do the step 2 applying to all the tables which contain the LineItem_ID attribute. To make the behavior correct in  more generic cases.
Atl least we definely need to have modified the dbo.Model_Connection dbo.Model_Connected_Parts because such tags exist in the export xml file.
Thanks Yuri, I hadn't even considered manipulating the projects DB directly. I'll explore that option.
