Do you mean
Reply
Solved! Go to solution
Custom Validation error dialog/text?
Is there a way to change the the text on the validation error that pops up in Engineer when the user types in a value that isn't valid?
Is there a way to change the entire dialog?
Gene
Gene Libardi
Principal Solutions Architect
Engineering Intent Corporation
www.EngineeringIntent.com
Solution
Solution
Accepted by topic author EIGene
‎11-09-2016 12:49 PM
Re: Custom Validation error dialog/text?
[ Edited ]
Just a thought
Probably we could make a custom validation message using conditions and msgboxes under the WhenChanged tab.
(I haven't quickly got it working)
