Reply
Solved! Go to solution
Adding custom symbols to Callout dialog box
Is there a way to add custom symbols to the Callout Dialog box?
My company has non-standard callouts that are used on a few select dimensions for incoming inspection purposes, these are not going to change to anything else.
Symbol gets placed adjecent to relevant dimension. My issue is that when I have these on drawing and the dimension gets moved or view gets moved, the symbol does not get relocated. I attached a screen capture of a drawing that has some on it. The 'M' in a diamond shape is on this drawing. All other symbols are in a diamond shape, others have different letters. Lower left side of drawing has a note indicating meaning and inspection requirements of each.
Gary Dinges | Mechanical Design Engineer II | Probes & New Product Development Emerson Climate Technologies | Therm-O-Disc, Inc.| 1320 South Main Street | Mansfield | OH | 44907 | USA T +1 419 525 8554 gary.dinges@emerson.com
Solution
Solution
Accepted by topic author Gary_Dinges
‎02-17-2016 02:05 PM
Re: Adding custom symbols to Callout dialog box
Why not use a diamond balloon shape with "M" inside linked to the dim? It will move with the dim and/or view.
Bruce Shand
ST9 MP3 - Insight - Win10 - K4200
Solution
Solution
‎02-17-2016 02:04 PM
That works !!
Thank You,
Gary
