Reply
Solved! Go to solution
Assemble part to part at default reference planes
All,
I am new to Solid Edge.
How do I assemble reference planes in PartA to the reference planes in PartB in an assembly?
I can go PartA to the Assembly reference planes but not to another part.
What am I missing?
Thanks.
Solution
Solution
Accepted by topic author mcavins
‎09-24-2015 02:50 PM
Re: Assemble part to part at default reference planes
mcavins:
You will need to make the reference planes for PartA visible, if they are not already.
For this right click on PartA in the assembly and select Show/Hide component from the context menu that pops up.
Check ON Reference planes in the dialog.
Now you should be able to use those planes.
~Tushar
That was it! Thanks.
