Reply
Assembly parts freedom of movement
Is there a way to quickly identify freedom of movement of a part within an assembly ? i.e show an arrow or something similar on screen or identifier that would quickly display how the part may move and what additional constraints are required
Re: Assembly parts freedom of movement
[ Edited ]
I don't think there is something like an identifier. I use the "drag component" option to see the freedom.
Solid Edge ST9 & AutoCAD 2017 user
Unfortunately, no there isn't.
Greg
I think this would be a good enhancement. Catia V5 has 'Constraints Analysis' and 'Degrees of Freedom', which can be useful in some circumstances.
585 ST9 Win 7
Thanks for the replies, yes I use drag to determine the allowed movement but it would be much better to simply be able to view this on screen instead of having to invoke a command
I have to go see what can move in sketches all the time. I just go around and see what moves to figure it out. Different specifics, same problem. At least the colors let you know when everything is nailed down with sketches.
[ Edited ]
NX has this tool ...
But you could use the "SEAssemblyRelationshipBrowser.exe" to see wich components might move and wich have relationship conflicts to another.
//Under SEST5 for example!
C:\Program Files\Solid Edge ST5\Custom\SEAssemblyRelationshipBrowser\bin\SEAssemblyRelationshipBrowser.exe
Yasser
Unfortunately no, SE doesn't provide similar tools to this.
AI has a "smoke & mirror solution" look at:
BR,
Imics
@Imics That would be nice to have in SE.
Bruce Shand
ST9 MP3 - Insight - Win10 - K4200
[ Edited ]
Typical demo "feature", but yes it would be cool in same cases ! Smiley Wink
How does it work at a large assy (50000+ parts)? Smiley Very Happy
BR,
Imics
