Reply
Solved! Go to solution
Can I to experiment simulation with "wind" loads in Solid Edge?
Solution
Solution
Accepted by SusanCinadr (Community Admin)
‎08-26-2015 04:32 AM
You can sort of, but you would have to translate your win...
You can sort of, but you would have to translate your wind load to a pressure against all surfaces that will "see" the wind load.  There is no CFD in simulation, so you can't simulate air flow.  Wind loads may also be time dependent with a constant wind pressure intermixed with bursts that cause dynamics.  You will only be able to simulate the constant pressure with no dynamics...
Ken Grundey
Production: ST6 MP14
Testing: ST9 MP1
Re: You can sort of, but you would have to translate your win...
Thanks Grundey!) No, dynamics? Bad! Can I simulate the variation of the pressure (like time dependent with a variable wind pressure intermixed with bursts)?
