Reply
Solved! Go to solution
Changing draft template / Cutting plane arrow direction
Good morning,
i am wanting to set our draft template to toward as default, if you right click on a cutting plane and go properties/Display you have option of toward and away, our defalt is away and i am looking to set our default to toward, is there am option some where for this ?
-Mervin
Mervin D. Yoder
CAD | Designing
http://www.keimlumber.com
ST8
Solution
Solution
Accepted by topic author Merviny
‎08-26-2015 04:32 AM
In your template, click on the Styles command, select Dra...
In your template, click on the Styles command, select Drawing View and then either create a new one or modify the existing one and on the Lines tab, select the proper cutting line options and then save all including the template file.
Ken Grundey
Production: ST6 MP14
Testing: ST9 MP1
Re: In your template, click on the Styles command, select Dra...
Thank you Ken, that's exactly what I had been looking for.
Mervin D. Yoder
CAD | Designing
Millwork Specialty
[cid:image001.jpg@01CEF67C.5D072510]
Phone:330.893.2251 Ext.339
www.keimlumber.com
Mervin D. Yoder
CAD | Designing
ST8
