Reply
Solved! Go to solution
Closing Variables Table
(view in My Videos)
Hi, is there any shortcut to close out of this table other than clicking on the x, or can you pin it some-where ?
Mervin D. Yoder
CAD | Designing
http://www.keimlumber.com
ST8
Solution
Solution
Accepted by topic author Merviny
‎08-26-2015 04:32 AM
Hi,   Yes, you have to assign a shortcut to Variable comm...
Yes, you have to assign a shortcut to Variable command!
Here is a little help (sorry for Hungarian UI):
BR,
Imics
Imics
Re: Hi,   Yes, you have to assign a shortcut to Variable comm...
Thank you Imics, that will be easy enough !
Mervin D. Yoder
CAD | Designing
ST8
Thank you, that will be easy enough !
Mervin D. Yoder
CAD | Designing
ST8
