Reply
Solved! Go to solution
Dimension precision in a parts list
I have a parts list in 2D draft with PMI dimensions from the part models. The PMI dimensions are exposed in the variable tables in the part environments. I can't seem to find the way to adjust the precision. They are at 3 decimal points in the variable table, but in the 2D parts list, they read at 1 decimal point. I've gone to file properties/units and no luck. Also tried the setting in dimension style, no luck.
Any ideas?
Solution
Solution
Accepted by topic author Planker81
‎08-26-2015 04:32 AM
Re: Dimension precision in a parts list
Found it. In the Column tab of Part List Properties you can change the precision in the property text - @3/NU is for 3 decimal points.
