Reply
Solved! Go to solution
Fastener when draged from tree come's in simplified????
I downloaded update 6 when it came out. I just notice this now.
I use Standard Parts to bring in my bolts. When they come in there are as Designed. Since there's no repeat option in Standard Parts. Once the part is placed, i'll drag it from the tree to place it some where else.Pre Update 6, the part would place as Designed part. now it come's in as simplified. I want them as Designed Part. Search the optons and could find anything
http://www.screencast.com/t/sIzjzopOTXGg
Solution
Solution
Accepted by topic author TDB
‎04-07-2016 11:09 AM
Re: Fastener when draged from tree come's in simplified????
Try this:
RMB on the Parts Library and toggle off "Use simplified part" frpm shortcut menu.
Here is a short video:
BR,
Imics
got it, thanks
