Reply
Solved! Go to solution
Flange creation Issue
I am facing a flange creation problem.
I attached a video.
Can anyone could help me ?
I tryied to use Contour Flange but have the same issue.
thank you,
Arek
(view in My Videos)
Solid Edge ST8 MP10
Re: Flange creation Issue
I found a solution.
See attached video.
thank you.
Arek
(view in My Videos)
Solid Edge ST8 MP10
Solution
Solution
Accepted by topic author ArekK
‎08-23-2016 08:17 AM
I'm not quite sure, what the problems really are, but I have found 2 easy and fast solutions to get Your flange.
Either sync or traditional, as You want
See videos Flange_01 and Flange_02
(view in My Videos)
(view in My Videos)
Hope it helps
Wolfgang
Thank you Wolfgang,
I tryied to use it but without positive results. I don't know why I had a problem, SE jammed.
Arek
Solid Edge ST8 MP10
what exactly doesn't work?
Wolfgang
Did you try making the base feature as a tab, then using contour flange with plane normal to curve and select the all around option?
ST9
Windows 7 Professional
Nvidia K2200 & Intel Xeon
"You're doing it wrong"
