Reply
Flatten JIS material
Hello everyone,
I need to flatten exactly SPCC material (SPCC _ S JIS G 3141) but i can not find this material in Solid Edge material database.
Please advice for me how to use this material.
Best Regard,
BuiTu
Re: Flatten JIS material
looks like std 1008 CDS to me?   you can download the properties from MAtweb and load them into your material table directly
http://www.matweb.com/search/DataSheet.aspx?MatGUID=145867c159894de286d4803a0fc0fe0f&ckck=1
alternatively, look up the properties on the Matweb site Matt suggested and enter the properties yourself.
Go to the applications button->Properties->Material Table
Find the Steel folder and right mouse click on it, then select New material.  Fill in the values.
I posted this because my browser doesn't accept cookies from Matweb so I found this way can work as I don't have to do this too often.
Frank
Edinburgh University
[ Edited ]
Thank you very much for your help!
I have been created new material with properties on the MatWeb.
As advice i choose AISI 1008 Steel for SPCC-JIS G3141
http://www.matweb.com/search/DataSheet.aspx?MatGUID=b76f3b18bd814e449d3a8b4a906af771
Please help me to review, It's correct?
Best Regard,
BuiTu
