Reply
Solved! Go to solution
Hiding Dimensions in Sync
I have this drawing in Sync with all dimensions. Trying to work around is a little overwhelming This drawing is very complex. I looked in properties, help, etc. How do you hide... Other than deleting.
Thank You
Solution
Solution
Accepted by MLombard (Community Manager)
‎08-26-2015 04:32 AM
Ibelieve you are in a part not a drawing?    But i think...
But i think you are wanting to hide the PMIs?
try this http://screencast.com/t/kmnT1zIR
Matt Johnson
Application Engineer
Ally PLM Solutions
matt.johnson@allyplm.com
http://allyplm.com/
Re: Ibelieve you are in a part not a drawing? But i think...
My bad... I should of been giving you a more detailed description of the
part. I am in assembly mode with Create a Part. If you will notice in the
image the dimensions are showing and nowhere to hide according to the
pathfinder.
http://screencast.com/t/4cCfg7dX
Once again my apologies
Thank You
yes, being specific about the environment and with detail to things like being IPA in a part is critical info...
I believe what you are seeing is one of 2 things.
1.) based on your modeling approach. with a sync part when a face is selected, any dimension that is associated to that face will expose. I ASSUME that based on this modeling approach all of these dimensions are somehow associated.
2.) each of these are a sketch and all sketches are shows. expand your sketch collector and hide un needed sketches?
Matt Johnson
Ally PLM Solutions
http://allyplm.com/
