Reply
How to change the view of part when Flashfit is activated?
How can I change the view of the part when I add it to an assembly(Flashfit mode)?
Part is viewed as transparent with all edges visible instead of ST5 when it was just transparent.
When I add new part with many edges it result quite annoying to find right surfaces!
It is based on the current view style. In your case in th...
It is based on the current view style. In your case in the image, the view style is shaded with visible edges. If you switch it to simply shaded, you will not have the edges displayed on the transparent part while using FlashFit.
Hope this helps,
Greg
Re: It is based on the current view style. In your case in th...
I see the difference about what you say, but in ST5 it was different..not all edges were visible when you were adding a part.
I'm the only in my office with this "problem" ,my colleagues still see the part as ST5 version..why??.
When it's just a cilinder the problem is minimal...but when you have multiple edge of big part it's quite annoying to find the right surface!
However thanks for the answer
waiting for other advices!
