Reply
How to convert a simple revolve into a flat sheet metal part.
We often cut flat bar stock and roll it into a ring.
What is the best techique to do this in sheet metal and create a flat pattern?
I tried to revolve a rectangular profile then convert it to sheet metal then flatten.  I thought that you need to pick the end of the part to convert it but I couldn't select it.  If I extrude a small flat section at the end of the ring it work but it seems like an extra step.  Is there are revolve tab?
Steve.
Steve
Tweeting @lussierinbox
Even the Longest journey starts
with a small step! Smiley Wink
Re: How to convert a simple revolve into a flat sheet metal part.
[ Edited ]
Hi @schonbek,
I find this paticular component design is still far easier in Ordered mode.....just making a single arc based sketch for a Contour Flange, and you don't need the flats on the ends to do it. Not that creating the small flats for a Synchronous part is a big deal, but it is extra clicking to create the geometry.
Design Manager Streetscape Limited
Solid Edge ST9 [MP3] Classic [x2 seats]
Windows 10
Yes that is the ticket. Now I remember...
Steve
A pleasure Steve.
Windows 10
What about etch?  That seems to disabled in ST7 is this right?
Steve
No, it's still there, it just requires a sketch [on the target face] to make it active.
Windows 10
