Reply
Solved! Go to solution
How to fix slight inaccuracies
Hi all.
Just wondering if I can round the actual precision of a part so it is perfect.
For example, I want to change a part that is cut at 89.999 degrees to 90 degrees so it can sit on another part in an assembly.  It would be nice if I could do this in assembly view.
Thanks.
Solution
Solution
Accepted by topic author Kuli24
‎08-26-2015 04:32 AM
Re: How to fix slight inaccuracies
You can edit parts from the assembly to change the feature size/angle to correct.  For Ordered parts you do this with Dynamic Edit.  For Synchronous parts you do this with Face Priority select.
Changing the dimension or edit fields rounding precision does not actually change the size/angle of the geometry and also does not "dumb" down the assembly constraints to be less precise.
Ken Grundey
Production: ST6 MP14
Testing: ST9 MP1
Thank you!
