Reply
Solved! Go to solution
I am using ST5, When i download solid edge ST6, do I need new license file or i can use the old one?
Can I get any document for solid edge ST6 setup procedure? Iwas wondering do i need new license file for it or I can use old one.
Solution
Solution
Accepted by MLombard (Community Manager)
‎08-26-2015 04:32 AM
You need a new license file.  If you look in the delivery...
You need a new license file.  If you look in the delivery folder for ST6 you will see a README file that has the setup information in it.
Ken Grundey
Production: ST6 MP14
Testing: ST9 MP1
Re: You need a new license file.  If you look in the delivery...
I don't know but for some reason I am not able to download that readme file.
If you downloaded the ST6 delivery package and extracted the contents, the README is located in the resulting Solid Edge folder.
Ken Grundey
Testing: ST9 MP1
I downloaded ST6 from following link and which only allowed me to download .exe file and not readme file.
https://download.industrysoftware.automation.siemens.com/download.php
That's a self extracting Zip file. Run the EXE to extract the package. Within the unzipped folder structure you will find the README.
Matt Johnson
Application Engineer
Ally PLM Solutions
matt.johnson@allyplm.com
http://allyplm.com/
