Reply
I have an assembly error "The assembly may have out-of-data links, therefore cannot be solved...
The error says "The assembly may have out-of-data links, therefore cannot be solved. Try using the Update All Links tool before adding a new constraint."
After I got this error, I cliked on "Update All Links" from Tool ribon, but still I have this problem.
I don't have any ideas  how to solve this error. Please help me...
It's hard to say what went wrong just by looking at the e...
It's hard to say what went wrong just by looking at the error message. Does it still give the same error if you activate all the parts in the assembly before running Update All Links?
Re: It's hard to say what went wrong just by looking at the e...
Yes, I tried but still have this problem.
I don't know what's going on...
What happens if you have all parts in the assembly "Activated"?
Design Manager Streetscape Limited
Solid Edge ST9 [MP3] Classic [x2 seats]
Windows 10
Nothing happens. I mean, all parts can be activated but the problem is not fixed.
My current situation is I assembled more than 100 parts and now I'm trying to make a gear relationship between two gears, and this is REALLY final assembly. If I finish creating this relationship, my work is complete. However, I can't because of this annoying issue...
