Reply
Solved! Go to solution
I want to replace Parts in Top Level Assembly to Sub Assembly.
like this.(.jpg file)
Solution
Solution
Accepted by topic author jsy
‎10-31-2015 07:59 AM
Re: I want to replace Parts in Top Level Assembly to Sub Assembly.
Select the parts you want to move.  Then on the Home tab in the Modify section is a Transfer command.
Brian Fritz
Solid Edge Certified Professional
ST8 latest MP
