Reply
KeyShot Animation Fade in
Hi
I have an Animation made in ST7 using the fade In appearance setting, In Solid edge animation this makes the part invisible until it fades in, which is what I want BUT when I try to render in KeyShot the part is visible from the start then when it gets to the point in the animation when the part fades in, it disappears then fades in.
How can I make the part not visible before the fade in?
Re: KeyShot Animation Fade in
Guess not then!
