Reply
Solved! Go to solution
Question about ST7 draft.
I have two sheets in a draft, identical. I want to type in the title of the draft in sheet A and it also appear in Sheet b. So sheet A and B have the same title name in their respective title block and it is only typed once. Can this be done?
Solution
Solution
Accepted by topic author Kreider_guy
‎08-26-2015 04:32 AM
Re: Question about ST7 draft.
Yes you can.
Go to the Application Button>Properties>File Properties and change the title there.
This will only work though if the Title on the sheet background is tied to the property text
Owner: Scott Lester Drafting & Design
Designer: Rotork Instuments
The key in the last response is "property text." If you are unfamiliar with it, I recommend you look it up in the help file. That will be the most comprehensive source for setting up Title Block information in your templates.
If, after you learn about Property Text, come back here with specific questions and we'll be happy to assist.
____________________________________
--Scott Wertel, P.E.
