Reply
SE Admin and Muiltiple Options XML files
Edges
Has anyone ever set up multiple optionXML files with different names in different folders on their file servers that are all configured by disipline and named accordingly.  Then run SEAdmin.exe from 3 or 4 SE clients at a time on each occasion pointing to the associated optionxml files that differ by disipline.
Just wanted to know it this was even posible?   My idea was to automate the SE clients configurations and user settings by disipline Mechanical, structural, Civil, Piping for example in a multi discipline environment?
I Remember back in the early versions it was one optionxml file to administer all SE clients regardless of disipline?   Any ideas?
Cheers
Phil
Re: SE Admin and Muiltiple Options XML files
Yes, we have 3 different Opions.XML files on our server. 1 is for a division that is separate from us, but their document are in a different site. I use 2 different XML files to manage the locations of Design documents and Customer documents. The XML files are in the same folder and I have to switch back and forth manually between them depending on where the Document needs to be released to.
Dale Smith
Mitsubishi Electric Power Products, Inc.
ST9 MP3 - Insight
We do this with 4 different groups.  I created a VB app to be able to switch them based on role but also needed to change PDM configurations based on the chosen role at the same time.
Ken Grundey
Production: ST6 MP14
Testing: ST9 MP1
Care to share the VB app?
Dale Smith
ST9 MP3 - Insight
Ken great to hear from you and see your still solid edging.......
Any chance you wpuld be able to share the VB app.  It sounds like something I'd like to be able to do also.
Phil
