Reply
Solved! Go to solution
ST Circular pattern on a cylinder circumference
Hi
Does anyone know if it possible to create a circlular pattern in ST of a hole on the circumference of a cylinder.
In ordered, I created the hole and then created the pattern as shown above.
In ST, I get the wrong orientation of the pattern plane and can't seem to change it:
Anyone with a bright idea?
Solution
Solution
Accepted by topic author Alan
‎02-09-2016 09:16 PM
Re: ST Circular pattern on a cylinder circumference
[ Edited ]
Hi @Alan,
Seems to work here....if you mouse over the edge to get the center, the pattern can be placed there......
Design Manager Streetscape Limited
Solid Edge ST9 [MP3] Classic [x2 seats]
Windows 10
Don't worry Sean, I was having a blond moment! I left the F3 / plane lock on.
