Reply
ST9 Etch Pattern !
Hello everybody!
My name is Giuseppe and i'm from Italy, working in Pellegrino group,
and i'd like to Know if there are some news about etching pattern in ST9,
from the this last post on the argument (284025)
it seems not possible to create pattern from one etch.
we work with PVC sheet on cutting and drowing plotters and SE etchin function is enough
important for us.
tahnks everyone
Boomic
Re: ST9 Etch Pattern !
ST9 still does not allow patterning of an Etch feature.
Ken Grundey
Production: ST6 MP14
Testing: ST9 MP1
but might it be possible to "pattern" the geometry in the sketch and afterwards etch the complete sketch?
Wolfgang
Not possible, i tried!
the "patterned" geometry is not a true geometry, it seems like projections not selectable for etch..
Boomic
As @Grundey stated you cannot select by feature but I am able to pattern an Etch using the Body selection option while in the Pattern command.
Does that not produce usable results?
Jason
LMGi
www.TLMGi.com
Thanks!
I'm going to try!
Boomic
Hello Jason,
...Really i tried so much times but ai didn't was able!
can you attach me an example?
i'm very curious
Boomic
LMGi
www.TLMGi.com
Jason thank you very much for your help and your patience!
actually it was necessary for me a pattern to use when i export the sheetmetal in a .dxf file
and i ave to put it on an established layer,
but when i go in flat pattern mode the etch pattern behaves as a normal sketch.
https://youtu.be/ZJxY4FN1x-Y
however, many thanks for the help
Boomic
Hi @pellegrinosrl,
Yes, it appears not to have been "enhanced" [fixed] as yet in ST9......you still cannot make an etching, from a patterned sketch.
Unlike using that same patterned sketch for other operations, such as cutouts, with the "Select from sketch" filter. Robot Indifferent
Design Manager Streetscape Limited
Solid Edge ST9 [MP3] Classic [x2 seats]
Windows 10
