Reply
Solved! Go to solution
Save as assembly with new part numbers
This question is based on Mirror -insert assembly copy
I have assembly 111 containing part a1, b1, c1, d1, e1
I save as assembly 111 to 222. but while saving as I want to save as its some parts i.e. b1, c1, d1 as b2,c2,d2.
So My 222 assembly will be consist of a1,b2,c2,d2,e1
Is there a way to do that?
My question is based on mirror of assembly using insert assembly copy command.
In case of mirror of assembly , it ask for output of part...rotate/mirror/exclude and also part no. etc.
the same way can we do that for save as command for assembly?
Please guide,
Thank you,
Manoj
Re: Save as assembly with new part numbers
-->View and Markup
Use Revision manager ...
Select which part you want to save as ..
Once you saved it with new name  then mirror it .. !
Smiley Wink  enjoy ..
MfG - Kind Regards From Germany
Viv
Solution
Solution
Accepted by topic author manojsonje22
‎08-29-2016 01:45 PM
I am using Solid edge ST9, I don't see option of revision manger in view and markup.
If possible, can you please share video or something for it.
Thank you
In ST9 its name is Design Manager.
Here is a video:
BR,
Imics
Thank you, It was really helpful! It works great!
Appreciate your help!
