Reply
Solved! Go to solution
Screw mate
Hi, i'm searching something like the screw mate in SolidWorks, in which you can select a shaft and mate that to an hole and when you'll rotate the shaft in will advance like a screw in a threaded hole.
There is something similirar in SE or i have to make something like a path mate to an helical sketch?
Solution
Solution
Accepted by topic author Modelero
‎11-10-2015 11:38 AM
Re: Screw mate
There are several ways to do this in SE but the simplest is to use the Gear relationship.
Run the command and select the Rotation-Linear option.
Hope this helps.
Art
