Reply
Solid Edge ST6 - Maintenance Pack 10 Announcement
Dear Solid Edge Customer:
The latest Maintenance Pack (MP10) for Solid Edge ST6 is now available for download.
Sincerely,
The Solid Edge Team
Release Notes:
--- Maintenance Pack Policy --
We release Maintenance Packs for CRITICAL items only. Maintenance Packs are available
up to a maximum of 15 months following the release date of the English version. The
release date for Solid Edge ST6 English was 7/19/13, making the Maintenance Pack
cutoff date 10/19/14.
--- Office 97-2003 File Types ---
Customers have reported problems with SEEC interacting with Office 97-2003 file types.
   Example: It not possible to open an excel spreadsheet from the Solid Edge variable table.
File open is failing because Microsoft Office 2010 added security checks relating to
opening Office 97-2003 files. Therefore, in order to open Office 97-2003 file types
in this manner the SEEC Cache folder location must be added to the Microsoft Office
application’s Trusted Locations.
   Example: Add the SEEC Cache location to:
     File->Options->Trust Center->Trusted center settings->Trusted locations
Download Location:
ST6 Maintenance Packs can be downloaded from:
   https://download.industrysoftware.automation.siemens.com/solid_edge/ST6/
Installation:
After downloading the Maintenance Pack to your machine, unbundle the zip file and then
dbl click on exe to install the Maintenance Pack.
E-mail Notification:
To receive direct e-mail notification for new Solid Edge Update or Maintenance Packs, subscribe
to the SFBmail notification.
To initiate your subscription, navigate to: http://support.industrysoftware.automation.siemens.com/general/email.shtml for the web interface.
Or send an e-mail message (message and subject line should be blank) to: sfbmail-subscribe.plm@siemens.com
This Maintenance Pack addresses the following PRs:
===Assembly===
PR 1885858: Frames is not updated properly when modifying sketch dimensions
PR 1984033: Adjustable part will jump away from its position after updating all links
PR 1991947: A specific part of an assembly is not translated into the resulting step file
PR 2225984: Alternate Assembly preview bitmaps not always being updated on save
PR 7138768: Assembly constraints will not resolve after edits with Large Assembly add-in
PR 7160098: Problems selecting a reference axis after the original is deleted
PR 1994198: Impossible to select component in frame application
PR 1984803: Failed assembly relationships when opening some alternate assembly files
===Draft===
1990232: Performance issue in drawing view update
PR 1992068: Prevented copying a view due from one document to another
PR 2236774: Dimension of value '0' is displayed in the draft
PR 7168524: Automatic centerlines were not all being created for an assembly view
PR 7171445: Losing Radial and Diameter symbols during import from DWG
PR 7171484: Angle dim Limit tolerances are incorrect after import from DWG
PR 7171605: Images such as TIF and JPG are not positioned in ACAD
PR 7176666: Most angular PMI dimensions do not display in PMI based DV
1989738: deleting a detailed drawing view leads to a crash
PR 1993512: Grid origin moves when opening previous version file
PR 1994463: Dimensions between Centerlines get wrong scale when doing a Copy/Paste
PR 1995014: Arranged dimension changes after closing the Draw In View mode
===Part/Profile/Sheet Metal===
PR 1971089: Suppress/unsuppress of group which contains plane do not work
PR 1978707: After creating revolved cuts a part does not flatten
PR 1991815: Flat Pattern fails, if using DIN.PZL instead of Standard Formula
PR 1991664: 'Discrete list' AND 'Min/max limit' are marked and cause a Syntax Error
PR 7147657: Family of parts EdgeBar display issue
===Insight===
PR 7152750: Folder map Dialog should never appear during File Open
PR 1984313: "Free Text" search problem with option "Search for results in subfolders"
===Insight Connect===
PR 1990745: Standalone Solid Edge Viewer doesn't open all parts as designed
PR 7142238: Revisions issue with LCA & Revise operations losing revision history
===Solid Edge SP, Server, Standalone Client, Solid Edge Client===
PR 7179508: Changing the Part container properties on the CPD does not take effect
===Solid Edge Embedded Client===
PR 1991572: Problem setting SEEC_ItemTypeList_SE Part and SEEC_ItemTypeList_SE Draft
PR 1992713: Incorrect Item ID when using display names
PR 1993092: BOM mismatch with Save As Copy of read-only Precise IPA'ed assembly structure
PR 7157794: Save Copy As on an item with a drawing, gives a different part number
PR 7164279: File - Open of read-only (migrated from TcE) Part file displays strange error
PR 7167956: Save Copy As creates undesired link between new Draft file and original Assembly
PR 7168059: Open as read-only setting uses stale data.
PR 7168465: MT9_Drawing item type naming rule patterns for ID and revision are ignored
PR 7169854: Item Name in Solid Edge CPD not synchronizing between Part and Draft file
PR 7170830: Insert Part Copy behaves differently in Solid Edge managed vs. unmanaged
PR 7174855: Save As of migrated data changes the Item Name on the CPD from original
PR 7175353: Remove All on the Project ID will not remove the Project ID for model and draft
PR 7176006: The Insert Weldment link is shown as a red question mark
PR 1992719: SESE not using Naming Rules on Item Id and Item Name correctly
PR 7181609: Preview Image on Cache Assistant dialog is distorted as width is increased
Fred White
Siemens PLM Software
