Reply
Solid Edge ST6 - Maintenance Pack 11 Announcement
November 20, 2014
Dear Solid Edge Customer:
The latest Maintenance Pack (MP11) for Solid Edge ST6 is now available for download.
Sincerely,
The Solid Edge Team
Release Notes:
--- Maintenance Pack Policy --
We release Maintenance Packs for CRITICAL items only. Maintenance Packs are available
up to a maximum of 15 months following the release date of the English version. The
release date for Solid Edge ST6 English was 7/19/13, making the Maintenance Pack
cutoff date 10/19/14.
--- Office 97-2003 File Types ---
Customers have reported problems with SEEC interacting with Office 97-2003 file types.
   Example: It not possible to open an excel spreadsheet from the Solid Edge variable table.
File open is failing because Microsoft Office 2010 added security checks relating to
opening Office 97-2003 files. Therefore, in order to open Office 97-2003 file types
in this manner the SEEC Cache folder location must be added to the Microsoft Office
application’s Trusted Locations.
   Example: Add the SEEC Cache location to:
      File->Options->Trust Center->Trusted center settings->Trusted locations
Download Location:
ST6 Maintenance Packs can be downloaded from:
   https://download.industrysoftware.automation.siemens.com/solid_edge/ST6/
Installation:
After downloading the Maintenance Pack to your machine, unbundle the zip file and then
dbl click on exe to install the Maintenance Pack.
E-mail Notification:
To receive direct e-mail notification for new Solid Edge Update or Maintenance Packs, subscribe
to the SFBmail notification.
To initiate your subscription, navigate to: http://support.industrysoftware.automation.siemens.com/general/email.shtml for the web interface.
Or send an e-mail message (message and subject line should be blank) to: sfbmail-subscribe.plm@siemens.com
This Maintenance Pack addresses the following PRs:
===API===
PR 1997369: No lines in DXF file when using the API Method .SaveAsFlatDXFEx()
PR 1991583: QueryByName doesn't return a result for the "Default" Attribute Set
===Assembly===
PR 1994134: When hovering over a Sketch with Connect relationship key points are not visible
PR 1995269: crash when applying certain display configuration
PR 7189285: fence selection performance issue with Steering Wheel enabled in large assemblies using Part Priority mode
PR 7164670: Cutout profiles not placed correctly in some cases with System Library
PR 1994706: SePvAdp.exe doesn't create a JT file from an assembly and exit with error
PR 1997910: new assembly relationships being created when editing an existing relationship
PR 1999083: axial align geometry not displaying properly with inactive parts when selected in the Pathfinder
PR 1129886: Fixed an abort in the assemble command
PR 7164279: Users are prevented from Edit opening Part/Sheet Metal files that are modified in memory
PR 7207561: Mass value in parent assembly is incorrect
PR 7173522: Not getting assembly mass based on user-defined quantity for nongraphic part
===Draft===
PR 1986615: Cannot delete link from draft file
PR 1996610: Dimension Style with ',' will not be exported to DXF
PR 7194191: The alignment shape does not move to a new sheet
PR 1128251: duplicate dimensions in a lot of drafts
PR 1997964: symmetric diameter detached if centerline is edited and view repositioned
PR 2247261: Parallel dimensions are abnormal
PR 7196026: abort getting physical properties in some cases
PR 7201475: Crash due to accessing a Null pointer
PR 2248233: The placement of dimensions changes
PR 7218956: Solid Edge crashes after using extend command
PR 1921943: locked dimension changes value when geometry dragged
PR 1986693: Item count balloons that don't have a parts list are not updating.
PR 2250765: Dimensions move when I open dft in ST6
PR 8252911: SE hangs when zooming and panning
===Part/Profile/Sheet Metal===
PR 1977497: property text not solved in this draft
PR 7188619: Material Table Editor not working with Excel 2013
PR 1129164: Crash when saving a Part file, where a feature is pasted in
PR 1973206: Split Body causes the bodies to rearrange
PR 8250101: can't copy sync sketch
PR 2248871: non-reproducible abort during file close
PR 1128844: NX9 part can't be loaded and saved to ST6
PR 1995423: Connect relation to peer geometry does not work by mouse click. The click should now connect the relation. Note: Due to numerous changes in ST7 and not all could be ported back to ST6. Therefore, the line highlighted will not remain highlighted.
===Insight===
PR 1990496: Edit Profile (Upload) pops up since ST5MP11 even the part haven't been changed
PR 1985438: File not found message when SE tries to open a renamed FOA, RevMan open OK
===Insight Connect===
PR 1959588: RevMan Copy of a Divide Part Master.par + both divided parts = wrong Insight link
===Solid Edge SP, Server, Standalone Client, Solid Edge Client===
PR 7182587: 'Part.Title' property is not updated in this workflow
===Solid Edge Embedded Client===
PR 7189106: Save as fails for this specific Teamcenter Item revision
PR 1991419: Different LOV displayed in Solid Edge compared to Teamcenter
PR 1127691: ST6 removes TC-Absolute-Occurrence Information during upload/check-in
PR 7210424: Assembly Save As does not honor revision naming rule if Item ID is changed first
PR 1128098: Poor performances when creating, saving, or revising a document
PR 7155782: Save As fails when Insert Part Copy used with TC10.1
PR 8250856: Sequence No. synchronization issue when moving from ST2 to ST6
Fred White
Siemens PLM Software
