Reply
Solid Edge ST7 What's New?
hey guys
i am not able to open the solidworks draft file in the solidedge st7
is there any option to open it in the draft part of solidedge?
i have attached an example file. someone please help me
thanks,
visahan
Re: Solid Edge ST7 What's New?
Hi @visa07,
You can't open Solidworks drawings directly in Solid Edge "YET"...this is a new feature coming in ST9.
Your file is not attached either...please try again, but you might need to compress [ZIP] it.
Your only option at the moment, would be to export it from SW as a DWG, DXF, or IGES 2D file format.
Design Manager Streetscape Limited
Solid Edge ST9 [MP3] Classic [x2 seats]
Windows 10
thanks for the valuable information sir
"You can't open Solidworks drawings directly in Solid Edge "YET"...this is a new feature coming in ST9"
* Yes, but via the same process and prerequisites of being able to open SW assemblies and bringing over "intelligence".....
Kevin Grayson
Solid Edge Technical Consultant
kevin.grayson@siemens.com
