Reply
Solved! Go to solution
VBA from excel to update all drawing views in a dft file
Hello solid edge experts,
I am trying to create a VBA in excel to open solid edge ST8
to open solid edge draft file and update all the drawing views in it which are outdated and save it.
The model is linked with excel and gets opened with VBA and did save as.
but i dont know the code to update drawing views.
I tried so many times but failed.
Please someone give me the code.
Solution
Solution
Accepted by topic author JacksonBeno
‎04-27-2016 09:17 AM
Re: VBA from excel to update all drawing views in a dft file
You need to run the updateviews command with the startcommand method
Private Sub Form_Load()
Dim objApp As SolidEdgeFramework.Application
Dim objDoc As SolidEdgeDraft.DraftDocument
Const TESTFILE = "T:\vbtests\testcases\cube.dft"
Set objApp = GetObject(, "SolidEdge.Application")
Set objDoc = objApp.Documents.Open(TESTFILE)
' Call the StartCommand
Call objApp.StartCommand(CommandID:=DetailDrawingViewsUpdateViews)
Set objApp = Nothing
Set objDoc = Nothing
End Sub
I'll try tomorrow and confirm sir.
[ Edited ]
Thank you so much. it worked for me.
I have so many dimensions in my model.
based on my excel the model changes ,
therefore i need to delete or hide few dimensions in dft.
is there any code on that.
Also kindly advice where can i learn there codes.
I am completely new to VBA.
My SE version is 108.00.00
What you ask for is surely possibile, the most difficult part is how to identify the dimensions you want to delete\hide.
You need to browse all the dimension in the dimensions collection of a draft and decide if keep, delete or hide it based on your rules.
Have a look at the "Programming with Solid Edge" in the learning center (information tab on the right).
https://docs.plm.automation.siemens.com/docs/se/108/api/webframe.html
This is a good start, also the Solid Edge developer forum
http://community.plm.automation.siemens.com/t5/Solid-Edge-Developer-Forum/bd-p/SEDeveloperForum
Sir,
What is the code to hide and show layers in dft.
here there is an example on the usage of layers.
https://docs.plm.automation.siemens.com/docs/se/108/api/SolidEdgeFramework~Layers~Item.html
you need to change the value of the layour property called "Show" from True to False
Again I suggest to read the SDK document referenced before.
