Reply
Wish: Chamfer from midpoint
I need this sometimes, a chamfer, but not on the complete edge:
It would be very helpfull if we could add a chamfer just like we can add a flange in sheet metal.
Someting like:
Solid Edge ST9 & AutoCAD 2017 user
Re: Wish: Chamfer from midpoint
The sheet metal is modeled.
Swich to the ORDERED PAR envirement.
Perform a symetric Cut.
Switch back to the sheet metal envirement
You can add other operations.
I hope it helps.
Yasser
Thanks for thinking, but it doesn't help.
In attachment my part
I needed to make a plane, with your method to.
I want to
click on chamfer
choose option: from center
ready
I have never used it, but give the gusset tool a try. It may be just what you are looking for.
A gusset is for sheet metal.
I want to chamfer a corner, but not the whole corner, only the middel part, like you can see in a prior post, I uploaded my work-around.
