Reply
Solved! Go to solution
how to change setting of scroll to zoom in -out from pan in drafting
[ Edited ]
how to change setting of scroll to zoom in -out from pan in drafting.
presently i am in st6 draft and when i scroll, whole draft sheet move up or down.
i want -when i scroll sheet should be zoom  in or out.
How to change setting.
Solution
Solution
Accepted by topic author ashish
‎08-26-2015 04:32 AM
Go to Solid Edge options while in Draft and Click on the...
Go to Solid Edge options while in Draft and Click on the Program Button in the upper top left.
Then go to View and you'll see this:
