Reply
how to open the edges of contour flange
im facing problem to open the edges of the contour flange. i have to open the the top edges of the flange. i also posted the same .psm (sheet metal file) alongwith screenshot.
Re: how to open the edges of contour flange
Hi there @RAHUL_SHAKYA,
Are you looking to "flatten" [unfold] your model?.....or modify the top mitered flange[s] to a different bend amount??....or ???
Design Manager Streetscape Limited
Solid Edge ST9 [MP3] Classic [x2 seats]
Windows 10
If I understand crystal clear then you want to set a small gap between top side of contour flanges.
You don't do this directly, but there is an solution.
Here is a video about this:
BR,
Imics
is there any other quick way to do this. or by defaults we can create the gap between them
Sorry, but I don't know better/smarter solution!
BR,
Imics
i think I have found an - at least for me - easier way to get what You are looking for.
Using the convert to sheet metal functionallity from ST7
Starting with a box, convert that with a gap to a sheet metall part, close the corne and finished
See the video:
(view in My Videos)
Hope it helps
Wolfgang
