cancel
AMESIM Simulink co-simulation
When i try to run the  Simulink model, it stops with an error unable to find S-function.
S-Function( AMESIM PLATFORM) is there but it is not working.
Is it because of compiler issue? or environment variable issue?
Also i have installed all the things needed for VC++ Compiler, what you have said in earlier blogs.
AMERun Ver R13 SL2
MATLAB/SIMULINK R2008b
Re: AMESIM Simulink co-simulation
Good afternoon SriniS,
Some few checks concerning your issue:
  • Simulink subsystem name must differs from Amesim models that will be imported.
  • Amesim model must be open (otherwise the S-function might be encapsulated in .ame archive)
  • Amesim S-function must be located in same direcotry than Matlab one.
  • Binaries must be compatible (generates a 64 bits S-function if you want to use 64 bits Matlab version).
Can you check all these points?
Hello Blac,
Yes my simulink model name and Amesim model name are different.
My Amesim is open only.
I need to know whether amesim has created S-Function or not? How check this.
