Do you mean
Reply
Solved! Go to solution
AMESim Crashing when using aircraft fuel system library
Hi
I'm using AMESim with the Aircraft Fuel System library to model a simple a/c fuel system
Any other example that i've tried simulating so far, using other libraries has ran fine. But when I try to run a simulation using models from the a/c fuel system library, the simulation crashes and I get the error "STDSIMDaemon.exe has stopped working"
Any ideas as to what might be causing this?
Re: AMESim Crashing when using aircraft fuel system library
Hi Jethro68,
could you please let me know what is the release of LMS Imagine.Lab Amesim you are using and the compiler you are using as well?
You may find the release in the menu bar Help and then About. For the compiler settings, please select Tools in the menubar, Options, and Preferences, select the Compilation tab in the Preferences window.
Kind regards,
Olivier
maybe you should try to recompile your system and than run the simulation.
Have you made any change to the sketch?
Solution
Solution
Accepted by topic author Jethro68
‎07-11-2016 06:40 AM
Hi all
Sorry for the late reply
I did manage to solve this. Just in case anyone runs into this kind of problem, the issue was that I hadn't set the fuel definition. This caused the simulation to crash without any warnings
Thanks to everyone who helped me with this
