Bug on Parameter / variable Display [14.0]
Since I migrated on V14.0; I noticed something weird today.
On some component, I am not able to see the parameter or variable from this component.
Instead I get the list of all components in my system.
Check the picture where I display the parameter and the variable on a orifice.
Thanks for any tip
Maxime
Re: Bug on Parameter / variable Display [14.0]
Hello mAx,
Try to run a "Check submodels...": in Sketch mode press CTRL+K and "Update all".
Another option could be to re-set the submodel of your orifice in Submodel mode.
Emmanuel
hello @Emmanuel_D and thank you fro your reply.
I did all what you adviced, but still the same.
Other information: I have an orifice which give me no problem, if I copy and paste this component, the copied component make me trouble.
Now I tried following: I take the orifice from the library, and the same is happening.
Alright, a quick restart of AMESim fixed it...
