Compilators compatible with AMESim
Hi everyone,
I'm new to AMESim and to this forum.
I'm looking for information about compilators compatible with AMESim (version 11 on). The objective here is to provide integration with Matlab/Simulink and Virtual Lab, for experiments.
Thanks in advance,
Portolon
Re: Compilators compatible with AMESim
Hi Portolon,
welcome to the forum!
Amesim comes with GNU GCC 32 bit compiler.
It is also compatible with Microsoft Visual C++ 32 or 64 bits.
Intel C compiler is also supported.
In Amehelp you can find more information in the FAQs available in the 'Begin Here' section.
Emmanuel
Hey Emmanuel_D,
Thanks for answering!
Yet looking for information, I'd like to ask two more questions:
Does Virtual Lab run in the same compilers?
Can I use Windows SDK 7.1 with both?
The last one is because matlab 2012b is compatible with Windows SDK.
Thanks again,
Portolon
Hi Portolon,
SDK 7.1 is also supported in Amesim for 64 bit compilation. I think it is also fine for Virtual.Lab but this needs to be confirmed.
You can either use the LMS 3D Simulation Solutions forum or contact your local support on www.siemens.com/gtac or call your local GTAC phone number.
Emmanuel
Hi Emmanuel_D,
Thanks! Appreciate your help!
Portolon
Hi there!
I installed SDK, my matlab is founding C++ compiler no problem, but AMESim does not detect it. How I can use SDK compilers? I need to build co-simulation with simulink system...
BR
Oh, found solution (should have checked all my search results first...)
https://community.plm.automation.siemens.com/t5/1D-Simulation-Knowledge-Base/How-can-I-install-the-V...
Community Manager
Hi there !
Great to see that our Knowledge Base is used AND useful Smiley Happy
Have a nice end of day!
Julie
