Complex Number representation ?
Hi there,
I am fairly new to Amesim, and have been trying to explore the option of representing a complex number as an equation in Amesim.
Essentially, I am trying to model an impedance of a hydraulic system and would like to represent the impedance as an equation (R + jX). Does anybody know a way of doing this? Is it even possible to do this in Amesim?
Thank you for looking and thank you for your help!
Re: Complex Number representation ?
Hi aero_g,
if you are interessted in the real and imaginary part of the hydraulic impedance you might use the linear analysis mode. There you have access to eigenvalues of the system depending on your linearization time. You will the real and the imaginery part of the oscillating mode. An other interessting point for you can be to plot a root locus diagramm and you will see the roots in the real and imaginary axles. RootLocus
