How display traction and compression results in beam structure
I would like to know how I can see the results of the tension and compression forces of a beam I am analyzing. I display the Von-Mises stress, but i dont find the tension and compression forces in each beam.
thanks.
Carlos
Re: How display traction and compression results in beam structure
Hi @Carlos_nys,
not sure which software you're using but you're more likely to get an answer if you move your post to Femap or Simcenter 3D forums. This is the 1D forum.
Emmanuel
ok,  sorry, and thanks
