How to deactivate Simulink interface, a FMI interface in RLM server status
I want to know How to deactivate Simulink interface, a FMI interface in RLM server status.
For example,
When LMS Amesim was open without any library.
RLM server status look like the figure 1.
Figure 1
And the figure 2 is the status When LMS Amesim was open with Hydraulic library.
Figure 2
Next, I deactivate Hydraulic library using “deselect” function in [Modeling] -> [Category path list]
So, server status changed the figure1
Lastly, I make a Simulink interface block (or FMI co-simulation interface block, either way)
And the status of RLM server is changed like this.
(lms_il_fmi_01 is a FMI interface module and lms_il_int_01 is a Simulink interface module)
Here's the problem, When I was deleting the interface block, RLM server status was not changed!
In other words, I want to deactivate the lms_il_fmi_01 or lms_il_int_01 module
figure. delete all interface block
How can I do if I want to solve this problems?
Re: How to deactivate Simulink interface, a FMI interface in RLM server status
Hello Kuro,
At the moment FMI and Simulink interface are not handled as standard libraries.
Once these licenses have been checked out the only way to check them back in is to actually close LMS Amesim.
Hello Kuro,
Another possibility here. If you do not want to apply any modifications to your LMS Amesim sketch, then you can start LMS Amerun—if you have a license for it—instead of LMS Amesim. With LMS Amerun, you should be able to start simulations on models having any kind of interface block. Let us know if this worked for you.
Kind regards,
Bruno
