cancel
I want to use 3D Finite Element Model component in LMS Amesim
For FEM_3D_plate_step1.ame example.
Use Virtual.Lab and Nastran for renumbering of mesh node
and setting Static compensation points
But, I wonder if there are any other programs for renumbering mesh node and setting Static compensation points?
Thank you for reading
Re: I want to use 3D Finite Element Model component in LMS Amesim
Since rev14,  you can use the configuration tool app associated with the FEM icon to create the file with the links between the mesh nodes and the ports number. Then you have the right static stiffness, when you connect this component to the rest of your system.
I hope that helps you regarding your needs.
